Machine Vision
Run time License
Hi everybody ,
I would create an inspection with VBAI that communicate with Labwindows/CVI and called by C API.
This application should be running in many machines at the factory..
1- does it takes a Run time license for each single machine or just one can be used for all machines ?
2- which run time license should i buy VBAI Run time license or CVI Run time license ?
Thank you in advance
Best regards.
(3,884 Views)
Accepted by Arrouma
The CVI run time is free. Just create CVI executables and you can deploy them without needing to pay for a license for each deployed system.
For the VBAI engine, you will need to purchase a runtime license for each deployed system.
https://www.ni.com/en-us/shop/product/vision-builder-for-automated-inspection.html
You will also need development packages for CVI and VBAI to create the applications on your development machine (which you probably already have):
https://www.ni.com/en/shop/electronic-test-instrumentation/programming-environments-for-electronic-t...
Hope that helps,
Brad
(3,857 Views)
Thanks for your response,
Does the LabWindows/CVI Base can do the trick (Calling VBAI API) ?
(3,847 Views)
Accepted by Arrouma
Any C programming language can use the C API to communicate/control VBAI as long as it includes the header/library that comes with VBAI and you install support from VBAI for this feature.
(3,842 Views)
