09-01-2005 05:50 AM
09-08-2005 10:28 AM
10-11-2010 09:34 AM
Did this issue get resolved?
I am using VB6 and using IMAQdx & NIVBAI. Everything has worked well until this morning when my customer reported this error. All software is licensed and verified under the license manager. Any ideas?
10-11-2010 10:51 AM
After investigating further, I wanted to post some additional information regarding my problem.
The error message only shows when I have the following command in my code:
CWIMAQVision1.Rotate CWIMAQViewer1.Image, myImage, 180
Before this step executes, I can successfully call commands with CWIMAQViewer1 and NIVBAIInspection.
When I look into the license manager, I do not see Vision as an option. I would think that this would be using the same drivers for all CWIMAQ related calls.
Thanks in advance for any help you may have!
