Machine Vision
SMB connector trigger PCIe 1473r?
I noticed there is a SMB connector on the PCIe 1473r. What is is used for? In the manual it said it's for trigger. Is it like a DIO module that you can add into the block diagram when you write the Labview program?
Best,
Matthew
(2,753 Views)
Accepted by MatthewTang
Yes,
This is DIO 0 that avalible on the board without using the Camera Link I/O Extension Board.
Other Digital input are avalible to the user only if you use the camera link I/O extension board.
https://www.ni.com/en-us/support/model.pcie-1473.html
https://www.ni.com/docs/en-US/bundle/camera-link-io-board-pcie-getting-started/resource/372736b.pdf
Amit Shachaf
(2,742 Views)
