Machine Vision
Saving data from color pattern matching
I am doing some image analysis and I used the vision assistant to get all the steps I needed done to my images.  Then I turned it into a Labview vi.  But the problem is that the part of the vi that does the color pattern matching out puts the data in a complicated array.  Says that the 1-d array is made up of clusters. It contains the x, y, angle, score, etc.  As well as the box data to do an overlay. I was wondering if anyone had any ideas how to get the data back out.  I am just trying to get the x, y, and the angle from it.
(3,526 Views)
You have to something like the attached vi.
If you just want the first element, replace the for loop by an Index array.
Hope this helps,
Paulo
(3,518 Views)
That solved my problem.  I didn't think of using a for loop to get the data.
(3,504 Views)
