Machine Vision
Problems of pattern matching with an executable built with application builder.
I wrote a Labview program which uses the Pattern Matching.dll (Vision)
After I built an executable with the Application Builder.
The application running on a PC with all Labview software installed has no problems.
If I run the executable (after installation) on a PC without Labview it runs without problems untill it has to do a pattern matching between images.
Someone can help me?
Maybe have I to install something concerning Vision?
Could someone help me?
Thank you in advance
GcDago
(3,462 Views)
GcDago,
"Pattern Matching.dll" is not exists. I guess you mean "NIVision.dll".
So, for deployment of application with Vision functions the best way is using Vision Deployment Engine.
Some instructions here:
How Do I Create and Distribute Executables Using NI-IMAQ, IMAQ Vision, or OCR Functionality? [link removed; article no longer available]
(3,461 Views)
If you are using IMAQ Vision then you need to purchase deployment software to deploy your application.
Matt
Not sure if you need a Engine or License or both.
778044-01 IMAQ Vision Deployment Engine for One User 1 - 2 $ 295
778044-00 IMAQ Vision Deployment License 1 - 2 $ 295
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,419 Views)
