Machine Vision
"ISO Out" Trigger Type in IMAQ
I tried to find what is "ISO Out" Trigger Type in function imgSessionTriggerDrive2.
There are three choices to select in Trigger type:
- IMG_SIGNAL_EXTERNAL - clear - external triggers TRIG(0)-TRIG(3)
- IMG_SIGNAL_RTSI - clear - RTSI bus
- IMG_SIGNAL_ISO_OUT - I really could not find anything to know what it is for 😞
Thank you for any answer
Lukas
(4,056 Views)
Lukas,
The 'ISO Out' trigger type is for use with a CVS (Compact Vision System) only - since it is the only National Instruments IMAQ system with ISO (or isolated) triggers.
I hope that answers your question. Have a great day!
(4,043 Views)
Thank you,
now it is clear.
Lukas
(4,037 Views)
FYI, the new PCI-1426, low cost Camera Link, also has a few ISO trigger lines.
(4,024 Views)
The PCI-1426 features two isolated inputs, but no isolated outputs.  The isolated inputs can be used instead of triggers 2 and 3 (this can be configured in MAX).
(3,938 Views)
Sorry, I meant triggers 0 and 1, not 2 and 3.
(3,932 Views)
