Machine Vision
Select whole image as ROI automatically
Hi everyone,
For the purpose of using pattern matching, I am first trying to select the area I want to explore. I use a camera from which I take photo and I want to analyze it later. I want to select the whole picture to find patterns (like circles or rectangles). My problem is that I need this to be automatic and I am not understanding how to configure the ROI. I tried to create a ROI descriptor but I don't understand how to send the data as a whole.
I have the feeling this is not very hard, but I think I am stuck in some thoughts. Can someone give me some tip to understand how to work with this?
Thank you!
(3,671 Views)
use this vi to lrean how to make ROI
use dirffernt RIO to find relate numbers and type of array points
(3,662 Views)
Thank you for the answer!
Unfortunatelly I can't use the file, as I am using the version 2012. Is there any chance to get a later version of that VI?
Thank you!
(3,645 Views)
Accepted by Rhen
(3,641 Views)
Thank you!
I managed to create a ROI in the program after reading that VI 🙂
(3,636 Views)
