‎02-13-2006 08:48 AM
‎02-15-2006 08:04 AM
Aleksandr,
Below are two documents which discuss this issue.
Transfering Images with DataSocket
Streaming IMAQ Images Over a Network (or Internet)
‎02-17-2006 04:18 AM
‎02-20-2006 02:52 AM
‎02-20-2006 09:10 AM
Aleksandr,
What version of NI-IMAQ and LabVIEW do you have?
This might be a version conflict.
Lorne Hengst
Application Engineer
‎02-22-2006 01:58 PM
Hello Lorne Hengst.
Thanks for the attention.
I have LV - 7.1 and Vision 7.1
With respect
Aleksandr
‎02-23-2006 01:52 PM
Aleksandr,
You mentioned that you are using a web camera. It is probably either a firewire camera or a USB camera. You will need to modify these examples so that they use the appropriate driver VIs for your camera.
So... replace all of the IMAQ driver VIs with the appropriate counterpart for which ever type of camera you are using (either NI-IMAQ for IEEE 1394, or NI-IMAQ for USB).
‎02-27-2006 02:17 AM
