Machine Vision
Sending Image with Overlays to LabView from VBAI by using shared variables
Hi. I am trying to send images from VBAI to LabView by using shared variables. I used set variables to set current image in corresponding network variable. I am able to read the image from LabView. However, the image is without overlays even though I used IMAQ Merge Overlay function. How can I get images with overlays in LabView from VBAI thanks to shared variables? Thank you in advance.
Message 1 of 12
(2,552 Views)
Hey! Came vi
Message 2 of 12
(2,533 Views)
Message 3 of 12
(2,522 Views)
Try to put a control screen (Image)  and see what's there. And after recording the image, the memory area needs to be cleared.Снимок экрана 2022-04-05 в 11.08.37.png
Message 4 of 12
(2,443 Views)
P. S. Unfortunately I couldn't open it vi. I have LabView 2017
Message 5 of 12
(2,513 Views)
I saved my VI as previous version. Are you able to open it right now attached VI?
Message 6 of 12
(2,509 Views)
I think that SV is not the right thing to send images. I would use network streams.
Unfortunately I have no experience with VBAI. In poor LV with Vision I would proceed like this:
  1. define a cluster with image and ROI descriptor.
  2. Convert overlays to ROI and send clusters via NS.
  3. On receiver side use IMAQ Overlay ROI.vi.
An example (LV2020) is attached and also saved for LV2017.
Message 7 of 12
(2,506 Views)
Overlays are created in VBAI and sent to LabView by Network Variables. Unfortunately, I have not seen anything like Network Stream in VBAI.
Message 8 of 12
(2,496 Views)
I think this solution will work
Message 9 of 12
(2,483 Views)
Here is more detail
Message 10 of 12
(2,474 Views)
