Machine Vision
Serial port on NI PCIE 1429 - OEM camera
Hello
Is there a way to connect using hyperterminal with the serial comport on the PCIE 1429 ?
I am trying to connect an OEM camera with the next setting :
Baud rate 115200
data length 8
start bit 1
stop bit 1
parity - No
Xon/Xoff control No
serial termination \r\n
The main problem is that I am unable to communicate using the " NI camera file generator " .
(3,347 Views)
Hi Shai,
Can you post the users manual for you camera?
Unfortunately the OS can't target it as a standard COM port.  You will have to go through the API in order to communicate over the serial lines.  The only interface I can think of is the one built into the Camera File Generator.
Joe Daily
may the G be with you ....
(3,333 Views)
