Machine Vision
SignalLevels' attribute of ICD file
Does anyone know the differences between following selections of SignalLevels field for an interlaced-camera :
         CSyncIn (RS422, Low)
         HSyncIn (RS422, Low)
         VSyncIn (RS422, Low)
v/s
         EnableA (RS422, Low)
         EnableB (RS422, Low)
         EnableC (RS422, High)
         EnableD (RS422, High)
(3,299 Views)
Hello nimaq,
The CSyncIn, HSyncIn and VSyncIn are used in camera files for analog cameras to specify the signal levels for synchronization signals compared to EnableA, EnableB... that are used in camera files for digital cameras to setup the signal levels for the frame valid and line valid signals. I hope this helps.
Nipun
(3,289 Views)
Thanks...
(3,287 Views)
