Machine Vision
Some time camera (IEEE1394) getting disconnected
Hi All,
I am working with a two camera inspection systems. Some  time when I start the systems, Camera getting disconnected from the system! And in device Manager it is showing Yellew device (i.e. Driver not found)
Once I update the driver in MAX, Application starts again.
Rgds...
Prakash Mahar
(4,792 Views)
Accepted by topic author Prakash_Mahar
Hello Prakash,
  • Does this problem occur when you start your system after windows is loaded (from reboot or previousely were shutdown) ?
  • Do you use any Windows Optimization Tools (that fixes registry etc?)
  • Do you keep updating your windows?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,776 Views)
Glad that your problem is solved
Assistant Lecturer
(4,683 Views)
Hi Prakash,
My team also having the same problem like yours. Need your help and advice on what have you done to solved the issue, since we also try to upgrade the driver,it's ok for a while and then it will happen again.
regards,
Dina
(4,495 Views)
