Machine Vision
Someone used Google Glass with IMAQdx?
Hello everyone. I would ask if someone used Google glass to IMAQdx. I need to get the images and then process with Vision Motion. I hope someone can responeder me. thank you very much.
(4,850 Views)
Since most of us don't have google glass, the likelyhood of you actually finding someone who has already done it are slim.
The next best possibility is that you might get it done with our help.  Here are some things to consider and try:
1. Does google Glass already have the capability to emulate a USB Camera on Windows?
If so, then it would be simple to connect.  This is probably not the case.
2. If Glass can send its video to an android device's screen, then you can install one of the virtual webcam drivers for android, and that will definately work.
3. If nothing else is possible, you may need to develop something specific for android and glass to accomplish your objective.
I have some posts where I have pointed ppl to the virtual cam software.  I don't recall where is is off the top of my head.  Just check my history.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,840 Views)
Thank you very much for your reply
(4,837 Views)
