01-06-2017 07:03 AM
Could you post a screenshot of your VI? I have an older Version of LV on my private PC an cannot open your attached VI.
01-06-2017 07:43 AM
I have lv2014 so I could not open your vi
but for help you
I create vi
this vi use method 1
also image name is frame number that you capture
reopen VS and reconfig for your camera name and enjoy it ![]()
01-07-2017 09:34 AM
Thanks a lot.It is working perfectly.. 🙂
01-11-2017 02:08 AM
Hello Again,
I want to do another task as an extension of this one. So, I want to identify a pattern while capturing image and camera should capture the image in defined time (i.e. 1 minute), if not, it will shut down again.
So, camera will turn on, start looking for pattern within the frame, if it cannot find within 1 minute, it will shut down, but if it finds withing 1 minute, it will capture the image with pattern.
So, how can I achieve it ? Could you please help me!?
How can I stop one while loop in two ways(either camera stops or Elapsed time).!?
Thanks 🙂
01-11-2017 08:09 AM
Hello All,
Please ignore my previous question. I have found the solution of it by applying ''or'' Boolean. 🙂
01-11-2017 08:52 AM
Hello Again,
In addition to the solution provided in this post I want to develop one step more in same file.
I want to identify and count the pattern in the online show which I am able to do it in Vision Assistant. But since my object's position is not fixed, I have defined ROI and Co-ordinate system in Vision Assistant which works perfectly in it but ROI and Co-ordinate system are not working as I desired in VI Labview.
Could anyone please help me.
Thank you. 🙂
01-11-2017 11:31 AM
01-11-2017 02:06 PM
oh ... ok..thanks 🙂
