Machine Vision
THE NI-DAQ Appears to me IN SOFTWARE BUT NOT Appears to me IN DEVICES WHY
I CNOT SEE THE NI-IMAQ BUT I SEE THE CAMERA IN DEVICES
(4,718 Views)
Hello דודי!
Could you please describe more clearly what is your issue?
Checking the screenshot you uploaded it shows both, the camera under "devices and interfaces" and the NI-IMAQdx 14.0 software under "Software".
>>Daniel C.
(4,705 Views)
YOU CAN SEE IN DAVICES Should appear NI -IMAQXD BUT MY MYRIO NOT SEE Software IMAQ IS CAN SEE THE CAMERA BUT NOT IMAQ.
AND I NEED TO CONECT TO MYRIO Through labview and open the camera Computer controlled from a distanc
(4,700 Views)
Hello דודי
Could you please try to describe better what is exactly the problem you're having?
Daniel C.
(4,668 Views)
Are you trying to use the NI-IMAQ API with the camera instead of NI-IMAQdx? That camera is only supported by the IMAQdx API.
(4,659 Views)
