Machine Vision
Error 0xBFF69031 GigE-SVS-Vistek cam: The system did not receive a test packet from the camera
Hello dear forum users,
until now I was successfully connecting a GigE-camera (eco204 from SVS Vistek) and reading frames. Suddenly there appears the error message "Error 0xBFF69031; The system did not receive a test packet from the camera; The packet size maye be too large or a firewall may be enabled" (see attached image). I checked that the camera is still connected and recognized by the "MAX", (measurement and automation explorer).
The windows firewall is off (by the way: using the camera on another computer was possible with firewall on). I tried also reducing packet size and resetting the configuration data in the MAX - the error message remains and reading frames is not possible.
Can anybody help? Is there an alternative to a re-installation of Labview?
Thanks in advance.
(6,111 Views)
Try changing the packet size to 1500. If it works, it means your network card is probably not configured for jumbo frames.
(6,094 Views)
Unfortunately, reducing the packet size down to 1500 does not solve the problem. Are there any other reasons for the abovementioned error message?
(6,057 Views)
in the following Link you can see some steps you can try for troubleshooting when you get the 'Error 0xBFF69031'
http://digital.ni.com/public.nsf/allkb/4D0ECFAA9AD9FF3E8625792600551A1E?OpenDocument
I hope there are some steps that might help you.
(5,956 Views)
