Machine Vision
Timeout occurs in MAX when grabbing an immage from a basler Scount scA1000-30gm camera
Zen,
Have you checked all the triggering settings and ensured you didn't enable some sort of triggering? IMAQdx will save the camera's settings and so if you turned on a frame trigger in the past it might still be set. You could also try switching the camera into a test image mode which would eliminate all triggering as a source of a timeout. You can find these attributes in the camera attribute tree. If you get a test image this indicates it is not a network-related issue you are running into.
Eric
Message 11 of 17
(2,397 Views)
Have you gone through this document and performed all the steps outlined?
-Zach
Message 12 of 17
(2,386 Views)
Hi Zach,
Yes, I have read this note and performed all the relevant steps outlined there.  I have come accross it before I posted my question on this forum.
Hi Eric,
I did check the triggering setup and the camera is set up NOT to use external trigger.  In fact, Pylon Viewer has no problem grabbing images from the camera, which makes me suspect that either there is something missing in my LabVIEW (8.6) installation or there is some confusing messup with the NI device drivers, or something...  To add to the confusion, I tried using identical camera on a different computer where LabVIEW 7.1 is installed with vision, etc. and get the same results.  This installation of LabVIEW (7.1) has been used successfully with a different camera, not GigE.
I have placed an order for the Intel PRO 1000 network card and am hoping that using that card will make the problem go away.
Thank you both.
Zen
Message 13 of 17
(2,384 Views)
Hi Zam...
Actually I have exactly the same problem.  Do you found some solution to this yet??
 I'll really appreciate this information.
Thank you in advance.
Nft
Message 14 of 17
(2,180 Views)
Hello everyone.
We already fix this issue; the solution was reduce the packet size for the camera and no timeout error occurs again.
I hope this will be helpfull for someone else.
Best Regards,
Nft
Message 15 of 17
(2,171 Views)
hello Ing. Nft,
i have the same problem how did you reduce the packet sizes.
thanks for advance
LabVIEW 2009, Windows 7
Message 16 of 17
(2,037 Views)
found it. it's under the acquisition attirbutes
Message 17 of 17
(2,033 Views)
