Machine Vision
Tomograph Files
Does anyone knows if it is possible to IMAQ BUILDER handle Tomograph files
(DICOM FORMAT)?
(4,792 Views)
IMAQ itself does not handle the DICOM format. You have to develop your own code to extract the JPEG images from the Tomograph file. We are currently working on DICOM files for Ultrasound & Angiograms which consist of a string header and then a pointer list that points to the start of each JPEG image.
(4,792 Views)
Hi Chris:
Do you have LabVIEW program that can open/save DICOM files?  I downloaded "DicomObjects", but it will be expired in a month.
Thanks.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
(4,457 Views)
HI Ricardo,
I found some DICOM library for LabVIEW. Hope this is of some help to you.
Sundar.
(4,395 Views)
Thanks.  Happy New Year!
(4,386 Views)
