Machine Vision
Triggering Basler Cameras From Software
Hi Everyone,
I want to use the Software trigger for basler cameras to take picture at a specific event.
the attached vi always give me a time out error and i don't understand the problem.
theoretically it should works, but maybe there is a parameter that i forget.
can anyone help me?
thanks
(4,920 Views)
Accepted by mon3am
Hi mon3am,
What is the timeout error code? At which function does the timeout occur?
Do you seen the same behavior when testing with an example grab with software trigger? (https://forums.ni.com/t5/Example-Program-Drafts/IMAQdx-Grab-with-Software-Trigger/ta-p/3774563)
Angela L.
(4,877 Views)
Hi Lagelin,
the error occur in the Snap Function.
thank you for your help
this VI is a solution.
(4,870 Views)
