10-11-2011 09:30 AM
Hey,
I'm having trouble connecting to my GigE camera in MAX.
I followed this tutorial: http://zone.ni.com/devzone/cda/tut/p/id/5846 and went through "The camera can be opened in MAX, but it does not acquire images" Case 2, but I still continued receiving the error attached.
What should I try now to get the camera to acquire images? I've also verified with the software that comes with the camera that I can acquire images.
And also, would I be able to use the camera with the ethernet port on my controller (PXI-8110)?
Kevin
10-11-2011 03:03 PM
10-11-2011 03:22 PM
10-11-2011 05:38 PM
Hi Kevin,
Did you try fixing the two things listed in the first error message? Specifically, disable your firewall and try reducing the packet size to 1500 bytes.
Eric
10-12-2011 07:15 AM
That got it working. I could've sworn I tried that before, but I guess not. Turning the firewall off and setting the packet size to 1500 got it working. I think also I may have fixed something about acquisition mode too. I believe the external triggers were enabled, but not exactly sure because I played around with a lot of settings.
