Machine Vision
USB port communication
Hi
I have built a visual inspection using Labview API this application show me if the objects analyzed are Correct o Incorrect, "Pass" or "Fail". I want to know if is it possible use the signal True or False to communicate with the USB port to use this signal to light on a green LED for Pass and a red LED for Fail. I have no idea how to use output signals i have never done this before. If anyone has some example code of this would be great.
(4,038 Views)
How are you communicating with the LED instrument on USB? Is there an interface/protocol provided by the manufacturer?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,032 Views)
Sorry but i didin't say that i would use the USB port with a USB/Serial conversor, so i would build a simple eletronic circuit using LEDs.
What want to know is, if is it possible to make something similar to this.
Thaks
(4,029 Views)
Ofcourse it's possible. There are multiple ways of doing it. One way you can do this is: Use a USB-6008, to output a digital signal (it has 12 DIO) to your circuit when the item is a 'Pass'. You will need to use the DAQmx API for this. Again, examples are provided in LabVIEW.
Adnan Zafar
(4,027 Views)
You said there is multiple ways of doing that, i am new in this field. If you list the other options would be great, must be a easy solutions because i am short of money and time.
Thanks for your support
(4,023 Views)
