Machine Vision
bead tracking algorithm
I want to track a dark line as it meanders through an image. I'm thinking to use a 3X3 grid, find the darkest pixel, center the grid on that, and loop around. (Obviously, a bit more complex than that.)
Rather than re-invent the wheel, I wondered if there is any existing code or maybe an example, that I could build on.
Many thanks,
Another
(3,796 Views)
Why dont you try IMAQ LOCAL Threshold function.
Silver_Shaper | CLD
(3,787 Views)
Thanks, I'll give that a try.
Incidentally, I found information on how the niblack algorithm works here: https://www.ni.com/docs/en-US/bundle/ni-vision/page/thresholding.html
(3,770 Views)
