Machine Vision
Unable to read QR code
Kindly ask for your assistance.
Trying unsuccessfully to decode a QR code through labview.
I'm able to read the code through online QR scanners (such as: https://www.online-qr-scanner.com/) or with some python codes but not with LabVIEW.
I'm attaching a small VI and an example image.
using LV2018 32bit. have vision module installed.
Anyone know what's the issue?
thank you in advance.
(2,875 Views)
Accepted by Tamir87
LabVIEW is a little more strict about the barcode requirements.  You don't have enough empty border around the barcode.  I added a small border with the same background color and it reads fine.  Try attached image.
Bruce
Bruce Ammons
Ammons Engineering
(2,847 Views)
interesting, thanks for finding a solution for my case!
(2,827 Views)
