Machine Vision
Unflattening a binary packed string
Hi.
I am trying to flatten an image to a string and then unflatten it again.
It works fine as it is now, but I would like to use compression.  I noticed the VI that I am using ("IMAQ Flatten Image to String.vi") has an input called "Compression".  If I set this to "packed binary" the resultant string is MUCH smaller.  This is good.  The problem is that I can't figure out how to unflatten the packed string into an image aftwerwards.
It works fine if I don't use any compression, though.  Attached is an example.
P.S.  I am using 256x256 8 bit greyscale images.
Any tips?
- John
Message Edited by John Paul Osborne on 03-12-2007 03:47 PM
http://www.medicollector.com
(3,803 Views)
Accepted by josborne
Hi John
Just as the documentation says, Packed Binary works only for binary images, i.e. the compression knows only zero and nonzero pixel values. I've made a simple test myself and it seems to me that after unflattening, zero pixel values stay the same and all the former nonzero values are put to 255.
Vladimir
View my profile on LinkedIn
(3,793 Views)
