Machine Vision
Usage of pci1427 with gap sensor and encoder
Dear all,
    I have a application dealing with a gap sensor and a quadrature input for encoder.So as per the application,whenever the gap sesnor becomes high the line camera which is connected should start grabbing according to the quadrature input pulses,So can anyone support regarding the daqmx configuration required interms of physical connection and configuring with the hardware.
Regards
Rajkumar
Sr.Developement Engineer
Message 1 of 1
(3,084 Views)
