Machine Vision
Using IMAQ Vision for glass bottle inspection
Does anyone using IMAQ Vision for glass bottles inspection? Is it possible with IMAQ?
(3,549 Views)
This really depends on what type of glass and the analysis that you want to do. If you can get good lighting and if the inspection that is being done can be differentiated well between pass/fail there shouldn't be a problem. Anything is possible.
(3,549 Views)
