I am looking into a way to test and MPEG-2 encoder/decoder. I have found the PXI-5431, that can generate a NTSC signal which is what I need and the PXI-1411. So, I guess my question is would this be a good set up to use the 5431 to generate a signal and the 1411 to acquire the signal and do some comparisons to the two. Has anyone done this type of testing? What type of comparisons could be done to the two video signals to verify signal quality(I know very little about video signals)?
Brian
