Machine Vision
Using Vision Assistant C Code in a Microchip Pic
Is it possible to use the C Code exported from Vision Assistant inside of a 8-bit, 16-bit, or 32bit Microchip Pic microcontroller?
I have an application that requires image processing at an embedded level, so I was just wondering if this was possible.  If not, what are my options for running Vision Assistant C Code on an embedded chip?
(3,674 Views)
Accepted by topic author Wurth_ICS
Sorry, the C code generated by Vision Assistant calls into the Vision Development Module, which is not available on that microcontroller.
Eric
(3,669 Views)
