Machine Vision
VBAI GigE change attributes on the fly
Good question Johan. We currently don't have support for this unless you're acquiring in Listener mode. This is a feature we will look into for future releases. A workaround would be to use product select to close the inspection and load a new one that doesn't have any acquisition. Then you could load a simple one that has 1 acquisition step and and you keep switching back and forth between the simple acquisition inspection an the empty inspection using product select until the simple acquisition inspection doesn't fail on image acquisition. Then you know you can load your real inspection and the acquisition will be good again....not very elegant, but a brute force way to get something working for now.
Hope this helps,
Brad
Message 21 of 27
(2,016 Views)
I have tried this without any luck, but maybe it will work if you can tell me how we can brute force our selves around your error message.
The one that occurs when you open the application without a camera connected.
Regards
Johan
Message 22 of 27
(2,014 Views)
Sorry I forgot about that dialog. You could just have a simple Run LV step that checks if your camera is available. All you would need is this one "Reset" inspection that keeps calling a Run LabVIEW step until the camera of interest is back online. The Run LV VI would just try opening a session and then close it and report if the driver could open a session (maybe enumerating would be faster, but I'm not sure). Once the driver successfully detects your camera again, then product select can reload your real inspection.
Hope this helps,
Brad
Message 23 of 27
(2,005 Views)
Everything has a solution, the problem is that it always involves Labview in some way. This run labview vi works (enumerate camera) but we are not going to have Labview installed on the machine that is supposed to run the Vision Application. So please provide us with a custom step for distribution as we are not able create our own.
Regards
Johan
Message 24 of 27
(1,960 Views)
You don't need LV on your deployed system for Vision Builder AI to call a LV VI. Vision Builder AI can run LV VIs even without LV on the system.
Hope this helps,
Brad
Message 25 of 27
(1,958 Views)
Ok, but can you tell me why I get this message, and where the nessesary files are located?
Regards
Johan
Message 26 of 27
(1,952 Views)
You need to build your VI into an LLB with all dependencies (including vi.lib). The info in the FAQ of the Run LV step describes how to package your VI for distribution. Once you follow those instructions, everything the VI needs will be in the LLB and you can move it to systems without LV and VBAI will be able to run it without problems. Feel free to send me your LLB if you continue to have problems and I'll see why it's not working.
Brad
Message 27 of 27
(1,919 Views)
