Machine Vision
VBAI Interface - Get inspection Image --> Image Dest
I have a complete Vision algorithm build in Vision Builder AI and programmed a VI in Labview which started the Algorithm and uses the results to compute. This works fine. Connection between Labview and VBAI is OK and results are nicely updated. Now I'd like to show the image from VBAI into my Labview GUI by using the "VBAI Interface - Get Inspection Image" VI from the Vision Builder AI toolkit. Whatever I try to connect to the "Image Dest" input of the VI I'm not able to let it run and give an image to show. See attached screenshot for details.
- What type of input do I need to link to get this VI working?
- Where can I find more detailed info than in the Context Help about all these VBAI toolkit VI's?
(4,810 Views)
Accepted by LouisvanWuyckhuyse
You need to use IMAQ Create to create an image. You can see an example of this in the Vision Builder AI folder under API Examples\LabVIEW Examples\LabVIEW API Example (Local).vi
Hope this helps,
Brad
(4,805 Views)
