Machine Vision
VBAI software trigger
How do you set the trigger software in VBAI using a USB Camera?
Thank you very much
(3,412 Views)
Accepted by topic author Irony
It is camera specific. Check out the Camera attributes or call the camera manufacturer to see where the SW Trigger feature can be enabled. Not all cameras support this, so it may not be available for your camera. Here's a sample of how to access it for a Basler camera:
Hope that helps,
Brad
(3,364 Views)
