Machine Vision
cropping the image
Hi I have been trying to crop the image defined only by the bounding box of the hole using the Imaq Extract vi but i Can't quite do it succesfully. Can you show me how to use this function? Since I have many figures can one automatically do cropping of this particular ROI since hole doesn't appear at the same locations in the image.
kreshnik
(4,748 Views)
Attached is my suggestion.  The only thing you might have to play with is the minimum threshold and that is only because of the thickness of the plate on the left side of the hole.  I will attach an image and the vi because I am not sure what version of LV you have.  This was done in 8.5.1.
Randall Pursley
(4,738 Views)
hello,
I need to crop the image based on block color border or based on some fixed border .Is it possible ??
(3,886 Views)
you have to change this border to ROI somehow
(3,871 Views)
Could u pls share some sample VI for that if u have any??
(3,866 Views)
could you attach your image here
(3,855 Views)
Please check the attached snap,i don't want the image which is outside the block color border.
i just wanna crop the image based on this block color border
(3,840 Views)
