Machine Vision
VIMBA with Labview
is there anybody who have succesfully used VIMBA SDK with Labview?
Message 1 of 10
(13,432 Views)
Accepted by MarcoMauri
You need to download version 1.3
Use the LabVIEW Import DLL tool
Point it to the VimbaC dll, not C++
Put _WIN32 in the compiler directives.  This will get you part of the way there.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
Message 2 of 10
(13,411 Views)
Thanks for replying!
We where trying to use the .NET assembly but it made Labview crash at the first call...
We'll follow your suggestions and let you know
Marco
Message 3 of 10
(13,399 Views)
I've successfully called the Startup() function and listed the available cameras.
Of course I had to fix the auto-generated VIs, but that's part of the fun.
Marco
Message 4 of 10
(13,364 Views)
I would like to use vimba with labview
i did say that MoviJohn but i'm stuck
Have you changed the VI and could you share?
thank you,
Message 5 of 10
(12,786 Views)
Hi Fred,
I had some problems calling VimbaC directly from Labview when big clusters were involved.
So, at the end, I wrote a C wrapper around the VimbaC dll...
Marco
Message 6 of 10
(12,779 Views)
Hi Fred,
I do not have a VI to work with VIMBA.  What I provided to Marco in this post was advice on how to import the VIMBA DLL into LabVIEW.  From there, you would need to study the VIMBA API.  I do not have any other exprience with the VIMBA drivers.  Sorry.
Message 7 of 10
(12,771 Views)
Hello MacroMauri.
I have recently been tasked to make a allied vision camera work with LabVIEW. i came across your post. i see that you had success creating a vimba wrapper for LV. i am having issues making it work. would you be able to post your wrapper. i would be greatful to you
Message 8 of 10
(10,372 Views)
any help MarcoMauri ?
Message 9 of 10
(10,338 Views)
Hi
I read that you were able to use the VIMBA SDK .net assembly .
When I try to open the constructor I receive an error that labview is not able to load the assembly.
I'm using labview 2016 64bit and the last vimba version 2.1.3
Please can you help me on this topic?
Thank you
Br, Orlando
Message 10 of 10
(9,082 Views)
