Machine Vision
Vision Assistant Password
Hallo,
ich benutze LabView 2011 in Verbindung mit Vision Assistant. Ich möchte das Bild von einer Intelligenten Kamera (Sensopart Visor V10) gerne über Ethernet mittels Vision Assistant in LabView einlesen.
Jedoch habe ich das Problem, dass ich diese Kamera im Vision Assistant nicht ansprechen kann. Nach Eingabe der IP-Adresse wird ein Passwort gefordert, welches aber nicht vergeben wurde.
Gibt es ein Standart-Passwort, wechles ich benutzen muss?
I'm using LabView 2011 with Vision Assistand. I want to read in the image of a smart camera (Sensopart Visor V10) by using Ethernet and Vision Assistant.
However, I have a problem that I can't access this camera in Vision Assistant. After entering the IP address, a password is required, which was not awarded.
Is there a standard password, wich I have to use?
(5,109 Views)
That would be the password you set in Max to password protect the device.
If none has been set, let the field blank, and you should be able to access the smart camera.
-Christophe
(5,103 Views)
The device isn't password protected - not from me and not from Sensopart.
Typing in no password doesn't work, Vision Assistant says: "The password was incorrect".
Thanks for help and sorry for my bad english....
(5,085 Views)
Sorry, I didn't read he original image carefully. Vision Assistant can only acquire from National Instruments Smart Cameras and do not support other like the Sensopart you're trying to access.
Christophe
(5,075 Views)
Ok, thanks for help!
(5,072 Views)
