Machine Vision
Vision Assistant error message
I have LV 8.0 and Vision Assistant 8.0 installed. I haven't run Assistant for a few weeks and when I opened it up today I got this message "Executable version (7.1.1) doesn't match resource file (7.1). Check your configuration."
What does this mean and what can I do about it?
(3,653 Views)
Have you recently upgraded LabVIEW version 7.1? Here is an article that describes why this error may occur, and a solution for how to fix it.
Executable Version (7.1.1) Doesn't Match Resource File (7.1)
(3,631 Views)
That fixed the problem. Thank you very much.
(3,625 Views)
