Machine Vision
ccd camera imaging
I have a small but serious problem with a program that runs our CCD camera, The camera does not support two way data transmission, so we have to first initialize the parameters and then start acquiring the images. I am really really new to LabVIEW, I could use all the help anybody could give. Thank you
(4,289 Views)
Hi Nakshatra,
Usually, the best way to get a camera working is to use Measurement and Automation Explorer (MAX), because it centralizes all the control and information for the camera. Can you see your camera in MAX?  Can you acquire images from your camera in MAX?
Maclean G.
Applications Engineering
(4,269 Views)
