Machine Vision
Vision Builder AI changing the "job" and start/stop inspection with NI-DAQmx URGENT
Dear users and support
I have a simple inspection with 3 different object. For now I have also 3 inspections for this objects.
My question is how can I chose with NI-DAQmx witch object to control(to load the right inspectio) and how can I start stop inspectio with digital input also conected on NI-DAQmx
Thank you for help
regards
Bostjan
(3,775 Views)
Use the "select inspection" function as described here: https://decibel.ni.com/content/docs/DOC-16603
To use a physical channel as a selector, have a look here: http://digital.ni.com/public.nsf/allkb/33364C17A30E3268862570890079DBD6?OpenDocument
Hope this helps
Regards
(3,759 Views)
What type of cameras are you usign with VBAI? If you use Smart Cameras, you can use one of the digital I/O to trigger and choose what inspection to run.
I.R.
(3,749 Views)
