Machine Vision
Vision Builder Inspection Auto-Start (for several programs)
Hi everybody,
It's my first question, I hope to get a positive answer.
I would like to Autostart an inspection in Vision Builder
-  Start directly in Run Inspection, but with the Run Status, I wouldn't push the "Start Inspection Button"
- Not for just one program, but every time I open a document, it start directly
I have seen the other Subject "Autostart an inspection in Vision Builder" of the year 2006, but it's only for one document, I need to choose other programs every time, with the same PC
I hope it's understandable and possible...
Thank you so much !
Alexandre
(3,120 Views)
you can use command line:
"c:\Program Files (x86)\National Instruments\Vision Builder AI 2018" \inspect "Tutorial 1 - Coordinate System.vbai"
or
Tools->Options->StartUp
or you can use API :
c:\Users\Public\Documents\National Instruments\Vision Builder AI 2018\Examples\API Examples\dotNET Examples\
(3,055 Views)
Accepted by topic author Alexandre2504
Thank you very much for your message, it didn't work directly, but after some research it worked.
On VBA :
Shell "C:\Program Files (x86)\National Instruments\Vision Builder AI 2015\Vision Builder.exe \inspect C:\desktop\ProgramName.vbai", ShowModus
I hope to help someone
(2,984 Views)
