Machine Vision
Vision assistant - Batch processing output data
Dear Forum
I'm using the NI Vision Assintant to perform some measurements and defects detection on some captured images. Performing a batch processing over a folfer of images, I'm trying to save/export the measurements made but the output file only contains:
C:\INL\image01.jpg 13-06-2014 14:57:36
C:\INL\image02.jpg 13-06-2014 14:57:37
While on the "measure Step" I have 3 areas defined (please see attached picture)
Is there any way to save this data for every image processed?
(5,838 Views)
Have you tried creating a vi from vision assistant and trying in labVIEW.
(5,807 Views)
Hello Muks
Thanks for the reply.
Yes, and it works fine. My only problem is that currently we are using this for some "offline" internal optical inspection, and for every run we have to "change" a bit the script . The persons operating the system are not familiar with labview and I would like to keep the simplicity of the NI Vision assistant on order to release me from that.
(5,803 Views)
I havent tried saving the result of batch processing from vision assistant. Let me try
(5,800 Views)
