Machine Vision
Vision assistant does not start the OCR training interface
clicking the "New character set" or "Edit character set" does not start the OCR training interface. I tried to reinstall vision assistant with no success.
(5,382 Views)
Can you give me more informations about the aplication? Which versions of software do you use? Was it working before? If so, have you made any changes to SW?
Jakub Prokeš
NI Aplication Engineer
Jakub Prokeš
NIEE Aplications Engineer
(5,373 Views)
W7 32b
LV 11.0.1.f1 32b
VA 2011SP1
Yes, but have not been using it recently.
Maybe 😞
The OCR interface utility located at ...National Instruments\Vision\Utility is working.
VIs in OCR Training.llb located at    ...National Instruments\Vision Assistant\Plugins are broken (the main VI).
Guess there are some referenced VIs missing but dunno what to reinstall, since those are expected to be located at \Vision assistant.exe\... ???
(5,300 Views)
So the broken interface is probably not a problem, rest of the plugins are also broken and run no problem in VA.
(5,297 Views)
Accepted by topic author Bublina
It looks like there's a corrupted library that includes the VIs. Try to replace that library:
1) Close any National Instruments software running on the machine.
2) Replace library 60 IVA OCR.llb, that should be located in C:\Program Files\National Instruments\Vision Assistant\Plugins\, with the one I attached here in the zip file.
Please let me know, if this will solve your problem.
Jakub Prokeš
NI Application Engineer
Jakub Prokeš
(5,291 Views)
Did this work?
Thanks for the reply.
Jakub
Jakub Prokeš
(5,281 Views)
Worked,
thank you.
(5,277 Views)
