12-13-2005 04:31 PM
12-14-2005 09:50 AM
I can answer part of your question. The IMAQ Vision Deployment License is just a piece of paper that gives you a license to run it on one computer. The Deployment Engine includes the CD with software you need to install the deployment engine on another computer.
I'm not sure why NI did it this way. My guess is that you buy the Engine the first time you need to install the runtime on another computer, then just buy the license after that since you have the software.
I don't know the answer on the debug license, but I would consider the Vision module to be a toolkit.
The IMAQ license is automatic if you are using an NI framegrabber. There isn't much reason for having IMAQ otherwise, since it is the driver for the NI framegrabbers.
Bruce
12-15-2005 05:07 PM
| 777859-03 | NI Vision Development Module | 1 - 2 | $ 2,595 |
