Machine Vision
Want to select DAQ for my application
Hi friends,
I am newbie to labview.. I am doing a project in which I have to measure the ball valve position.. for this I have attached ring magnet below the ball. when the ball rotates the magnet rotates along with ball and by using hall sensor we can measure the position.
I will be using max 2 hall sensors... for this application, which DAQ is better.. cheap and best 🙂
Thanq
Every Expert was once a Beginner!!
(3,213 Views)
This is the wrong forum for such questions.
So you could either post this at the Data Acquisition Forums or, which is the better idea, send an email or call your local NI Office.
Please also provide a bit more information regarding your sensors, e.g. voltage levels and also about acquisition rates you will need, and what kind of system should control this application, e.g. Windows Desktop PC or mobile Laptop, and so on.
Christian
(3,189 Views)
