Machine Vision
What additional work need i do when runnig windows exe application(VS2013 c# project exproted by NI Vision Assistant)?
Hi all,
I write a .vascr vision project with NI Vision Assistant 2014 sp1,then export to .net project in vs2013.On my development computer,the exe application worked successfully.But on a new computer without NI Vision or VS IDE,it cannot inited. (the target PC has installed .net framework,and it can run common C# program).
The specified code which cannot run is:
            this.imageViewer = new NationalInstruments.Vision.WindowsForms.ImageViewer();
So,what need I do before run the exe application?
Thx!
(3,322 Views)
The problem's been solved by myself.
(3,316 Views)
