Machine Vision
how to read image file name
hi,
      how to read image(.bmp) file name.
(3,719 Views)
List Folder Function will return the files in a specific folder and you can give the pattern to filter only bmp files: http://zone.ni.com/reference/en-XX/help/371361M-01/glang/list_directory/
-If you want the image reference name in buffer you can simply create an indicator(Not the display) to the wire and it will show the buffer name.
uday
(3,713 Views)
hi,
         i want to read image file name. when i select image in 'Image browser' that particular image name only not all image name.
Ex: my image saved(natural.bmp).i want natural only.
(3,707 Views)
(3,704 Views)
use this code
(3,695 Views)
