Robert,
I'm not sure if I understand exactly what you are asking here, but you can use the Get Buffer function call to access the image data and it will coorespond to the image type that you acquired (8 bit integer for monochrome and 32 bit for RGB).
Let me know if this doesn't answer your question.
Andy Bell
Application Engineer
