Machine Vision
When will simultaneous control of multiple NI-IMAQ cameras (1394 devices) be supported on a single card?
Robert,
As far as I know, it should work right now. It does depend on the bandwidth each camera uses. If the two cameras combined use more bandwidth than is available, you are going to have to decrease the frame rate.
Bruce
Bruce Ammons
Ammons Engineering
(3,222 Views)
