Machine Vision
Where is NC-SI Port on IC-3173
Hi
I use 3173 FPGA I/O, there are four NC-SI ports, but it is not Iso Input, iso Output,  Differential I/O or TTL I/O. Which hardware dose it control? POE port?
CLD
CAU
(4,084 Views)
The NC-SI stands for Network Controller Sideband Interface and it would be for the Ethernet.
https://www.intel.com/content/dam/www/public/us/en/documents/application-notes/nc-si-overview-and-pe...
(4,062 Views)
Accepted by lizhuo_lin
Those nodes allow the FPGA to send and receive traffic from the network ports, bypassing the system’s CPU. Using these nodes directly takes some significant effort.
The Vision-RIO Driver API makes use of this internally to determinstically trigger GigE Vision cameras over Ethernet, without any extra cables.
(4,054 Views)
NI provides any documentation or example to use this Network Controller Sideband Interface under LabView FPGA?
(1,008 Views)
