Machine Vision
Where is the CWIMAQViewer control in VB.Net?
Where do I find the IMAQ Viewer control in VB.Net?  I have measurement studio and vision development module installed but I can't find an image control to drop on my forms.
Thanks.
(2,942 Views)
The CWIMAQVIEWER is found under the Active X Control from the toolbox. If you do not see it there right click the tool box and select Choose Item and then under the COM Components tab select the CWIMAQVIEWER. If you do not see it there then you do not have the .NET IMAQ drivers installed or you’re not using the correct version of .NET.
Tim O
(2,930 Views)
