‎05-11-2010 03:15 AM
Hello everyone,
I'm working with PXI-1411 on RT system. The frame rate is 25 per second. I used IMAQ write file 2 to save images in seperated files. But it caused always images lost. Because the velocity of IMAQ write file is much slowier than velocity of image acquisition. But i can't save images to AVI file., because it doesn't work on RT system. Do you have any suggestions to solve this problem. Thank you very much.
‎05-11-2010
05:32 AM
- last edited on
‎05-17-2026
03:23 PM
by
Content Cleaner
Did you streaming the video
‎05-11-2010 05:44 AM
‎05-11-2010 06:29 AM
‎05-12-2010
02:58 AM
- last edited on
‎05-17-2026
03:23 PM
by
Content Cleaner
Hello Zhongge,
yes you are rigth at the moment the avi function dosent support rt targets. But you are able to use the streaming function for that.
Link: http://zone.ni.com/devzone/cda/epd/p/id/6000
Kind regards,
Elmar
