Machine Vision
acquire images at the rising edge of a continuous pulse signal
I want to acquire  images at the rising edge of a continuous external pulse  signal .The external pulse signal is generated by other equipments.How should I integrate this continuous pulse signal to the CCD or IMAQ board? Is it to connect this pulse signal to one of  TTL -trigger directly?
Look forward for any advisable reply.
(2,993 Views)
Hi xiao,
Clarify these doubts,
Do you want to trigger the camera? If so which camera you are using?.
Silver_Shaper | CLD
(2,991 Views)
